sebna
Post by sebna »
There is a simple way for everybody to create their own specific version for their device with HEX editor. It is possible even now if only one condition is met. Your device string has to be equal or shorter in character length to the hard coded string in a version you are trying to modify for your needs.
Below is how to do it on example of 9.00 AVX2 TF which I will modify so it is going to be usable on my Meitner MA-1.
Description to the pictures under the pictures ;)
In picture above we can see original unmodified 9.00 AVX2 TF. Solid blue highlights TF device string. The red rectangle in hexadecimal section starting with "01 19 0A" octets marks the beginning of code which we cannot touch as it is no longer part of device string. The green rectangle highlighting 00 octet is still part of space reserved for device string but it is in fact not used by the TF string. It is just an empty space which we can use if there is a need for it. This last 00 octet is last usable space for us to work with. The same space as highlighted by green rectangle is marked by green arrow on right hand side. It is represented with a dot on the right hand side.
In picture above I have already pasted in Meitner MA-1 string over TF string (in free Hex editor which I am using, called HxD the function is called "paste write" from context RMB menu - link for the App on the bottom of the post). Pasted in Meitner MA-1 string is visible in red font. The green rectangle highlights the rest of space assigned to device string in the code which is currently filled by what is still left from TF device string.
In picture above I have erased what was left from TF device string by typing 00 in all octets in hexadecimal part (important to do it in hexadecimal part so where the green rectangle is on the picture 3) so only Meitner MA-1 string is left without any leftovers of TF string.
Done. Save file and we have just created 9.00 AVX2 seb version.
Now the only problem is that TF version has the longest string of custom versions and most of new requests strings are longer then that so we would need a version with longer dummy string to be able to replace it with potentially any string out there (not to mention that TF version comes only in AVX2 flavour and normal versions are so far based only on mine and jlring strings which are very short and not usable for replacing with other requested devices which strings are simply longer).
Which brings me to something I have spoken about with Gordon on PM that it would be possible for Gordon to go back to producing only AVX2 and Normal instruction sets for each version he produces and then everybody could HEX edit their string into their Normal or AVX2 version depending on their needs. The only requirement for this to be possible and flexible enough to cover all types of strings would be to compile them with long enough dummy device string to cover for hopefully all device strings out there.
For example my sting for Meitner is about 90 characters. So if both normal and AVX2 versions of each new "universal" iteration would be compiled by Gordon with dummy sting of:
Code: Select all
\\?\tusbaudio_enum#vid_20b1&pid_0002&ks#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\pcm_out_02_009999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999
which is about twice the length of TF that would leave plenty of space for pasting in any string and zeroing what is not needed to the end of string space allowing for everybody to have their dev version.
Anyway something to think about.
LINK to free Hex editor I was using -> http://mh-nexus.de/en/downloads.php?product=HxD
How to get your device string if MQNDevinfo.exe does not work for you:
John Dot wrote:Sebna has found the method to find the right string. Finally!
Download Aplayer http://albumplayer.ru/english.html
go to the EXTRAS->KS and run "ks_x64_config.exe", set the right device and press OK. "APlayer.ini" will show in the folder and there it is THE MYSTICAL STRING :)
so mine is:
\\?\pci#ven_13f6&dev_8788&subsys_835d1043&rev_00#4&30d54f48&0&00f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\aa_wave
uploaded 3.91 and 3.92 avx2
think 3.92 is same as 3.83, is 3.91 an improvement ?
don't think so
jrling wrote:I feel I have dropped off the wagon too. The last MQnPlay Normal that was not device specific was 8.92 on 11 December. Since then it has been exclusively AVX2 and device specific.
That's not a complaint, but it is marginalising those like me who can only use Normal. Ditto MQnControl with 3.84 being the only recent Normal version.
do we need a whip round to get you a haswell ? There's quite a step up in sound quality between normal and avx2. It's a bit like developing an F1 car, the technology get's passed down. Think we're nearly there with SQ, so next will be functionality. Never know, might integrate it with foobar, wonder what they would say to that.
thanks sebna, should help until I get auto device working or if fixed still sounds better than auto.
John Dot
Post by John Dot »
sbgk wrote:thanks sebna, should help until I get auto device working or if fixed still sounds better than auto.
My string is 22 chars longer than Sebna's, so is 64 empty characters enough for everyone?
sebna
Post by sebna »
Mine is 97 according to MS Word so you must be counting it somehow wrong.
In my previous post I have posted a sample dummy string which is about 160 characters. That might be enough for everyone but possibly 200 would be a safe bet.
John Dot
Post by John Dot »
sebna wrote:Mine is 97 according to MS Word so you must be counting it somehow wrong.
Sorry my mistake. Mine is 113 characters long. Dummy string is a great idea IMO.
In fact Hex editing the Mqn.exe is less complicated than setting up the Bughead :)
Ah, be adventurous - integrate it with JRiver & get loads of publicity when they refuse supporting Any JRM that uses MQN.
You could probably really get this ball rolling by renaming MQN to MRJ MJR or some combination of JRM :)
BTW, would it be easier to have MQN always work with some virtual device ID name & some way of mapping an existing physical device ID to this virtual device ID? Don't know if this is possible or if it would be as sonically effective as the existing fixed mapping?
thought meridian were getting close with mqa !
sbgk wrote: thought meridian were getting close with mqa !
Yea Master Quality Authenticated - what does MQN stand for again?
But I don't see Meridian making any claims that using their MQA if used with JRMC will improve the sound - that's JRiver's main worry, it seems.
