Hey Guys,
I'm selling my Turntable DUAL CS-455-1 if anybody interested :)
Asking price: 155€ (retail price: 600 - 1000€ http://soundapproach.com/dualcs4551full ... -1445.html)
Automatic Belt Drive
Excellent condition (upgraded with silver wires)
Incredible Sound, working perfectly
Tone arm:
•Cardan bearing with zero-mass tracking force setting thanks to precision torsion spring
•Removable headshell with 1/2 inch fixing holes
•Adjustable tracking force and anti-skating
•Carbon-fibre headshell mount for high torsional rigidity
Chassis:
•Solid wooden frame
•Floating subchassis
•Vibration-damped aluminium platter with anti-static felt mat
Drive:
•Belt drive with polished flat belt
•DC motor with electronic speed control
•Viscosity-damped tone arm lift mechanism
•Automatic tone arm cueing mechanism
•Autostop with tone arm return
•Possibility to play old Shellac Records
• Ortofon OMB 10 magnetic cartridge supplied
Dimensions/Weight: 440 x 119 x 360 mm / 5.8 kg
Specifications:
•Three Speeds (33/45/78)
•1/2 inch headshell mount
•Cue Control
•Fully Automatic Operation
•Anti resonant feet
•Floating Chassis
•Belt Drive
•Solid Wood Console •DC Motor with Electronic Speed Control
•Viscosity Damped Cue Control
•Colour: Black
Turntable DUAL CS-455-1 - SOLD
Re: Turntable DUAL CS-455-1
Nobody want my amazing turntable? :-P
OK....have not used a TT for 20 years so i will jump back in just for comparison to my PC based listening.
Sold all my vinyl many years ago so i will have to start again, was looking at vinyl recently just so happens.....
I will send you a PM.
Cheers,
Pearse.
Cheers,
Pearse.
Good price for a good deck. Welcome back to the Dark Side!
Re: Turntable DUAL CS-455-1 - SOLD
Dual TT now set up (thanks Stephane) with vinyl but in my haste and not having used vinyl for 20+ years i forgot i needed a Phono Stage!!!!
My Preamp Conrad Johnson Premier 14 does not have a phono stage....still learning!
Can anyone recommend a good Phono stage, willing to pay up to €500 for one that goes well with the Dual, CJ kit and Quad electrostatics?
Cheers, Pearse.
Cheers, Pearse.
I have a Tom Evans Microgroove + set up for a Sumiko evo 3 cart (moving coil high output) here. Worth trying.Sligolad wrote:Can anyone recommend a good Phono stage, willing to pay up to €500 for one that goes well with the Dual, CJ kit and Quad electrostatics?
Would it have to go back to Wales to be set up for the Ortofon MM cartridge Ivor?
From what i have read so far there is a big difference between MC and MM cartridge setup.
Appears to be a good phono stage from several reviews i have read.
Might drop in to Cloneys this week to see if they have any i can try.
It would. I'd cover the cost of that.Sligolad wrote:Would it have to go back to Wales to be set up for the Ortofon MM cartridge Ivor?
Ask Noel for his opinon on the amp and if it's worth sending back (you can mention it's mine). He deals with Tom Evans regularly.
I could be wrong but I think that the set up for the sumiko high output mc is the same as for mm carts.
