7.95 2496 avx2 sounds very good.
Ken Moreland wrote:7.95 2496 avx2 sounds very good.
realised 7.95 was a vanilla c++ render loop version
7.96 is the fully optimised assembly version, is it any better ? find 7.95 a bit tiring to listen to.
7.98 - might have discovered something about wdm ks filter selection, seems more transparent
uploaded 7.98 16/44 and 24/96 normal/avx2 versions, think this is the best I've heard.
yup, not heard anything like this before, as big a break through as there's been, simply amazing sound.
Does anybody else (beside Tony and myself) have this problem often with the Main Page:
"Sorry, you can't view or download this file at this time.
Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator".
cvrle59
Post by cvrle59 »
sima66 wrote:Does anybody else (beside Tony and myself) have this problem often with the Main Page:
Same here...:(
3daudio
Post by 3daudio »
Same here... perhaps MQn is getting more exclusive...?
3daudio wrote:Same here... perhaps MQn is getting more exclusive...?
No issues here.
Are you logged in with a Google-account?
I am and maybe Google puts in some restrictions for those who are not?
m.massimo
Post by m.massimo »
No problem after logging in.
Fujak
Post by Fujak »
+1
Yes, logging in does the trick. Otherwise no chance any longer. In former times it was possible without logging in. Probably too many downloads in the meantime.
Sorry didn't think anybody else had the problem but yes once you log in to your google account download works fine. Also I have downloaded since without logging in so thought it was a temp problem.
TioFrancotirdor
Post by TioFrancotirdor »
7.98 normal, both 24/96 and 16/44 no sound :(
Ubuntu Live USB in RAM
