Octagon
Post by Octagon »
sbgk wrote:uploaded v29 for win8.1 users, can someone try it, not sure if it'll work with win 12 srvr, win8 won't work.
Hi Gordon,
Working with R2 Server 2012, Core Mode with AO 1.30 (and 1.31 alpha by the way) normal OS loaded and RAM loaded.
Very detailled! V29 is much more sensible if other tasks on same CPU Core as the ones before. The moment before I sorted MQnplay and Acourate Convolver via Tasker to different cores and priorities there where hickups. After v29 runs well.
Aleg wrote:Don't have regular Server 2012 anymore.
@Aleg
Which OS are you on at the moment? Testing W10?
My 2 cents
Thomas
Edit: Cancelled comment on files not playing: I was trapped by the 50MB limit :(
@Aleg
No I'm running Server 2012 R2.
I was trying to say I am running the R2-version (equivalent to 8.1) and not the regular 2012 (equivalent to 8.0).
I believe Gordon is now getting into assembly code that could be specific for 8.1 and equivalents.
whats the dll for?
nige2000 wrote:whats the dll for?
if i'm correct, it was for lekt to check on something, not meant for us
elaprince
Post by elaprince »
Aleg v29
How should we use it?
What else need to be in that folder to play?
Thank you
v30 is about as good as it's going to get
elaprince
Post by elaprince »
Gordon
Is this still for Haswell?
If not what are the other files I need with this V30?
Thank you
elaprince wrote:Aleg v29
Thank you
Just read this post from March 30st
http://tirnahifi.org/forum/viewtopic.php?p=69731#p69731
sbgk wrote:v30 is about as good as it's going to get
V31 is truly superb!!
Can we have a full load too instead of just 50 MB, I'm getting eager! :-)
V30 and v31 do run constantly with about 26% on a dedicated cpu core.
V26 runs at 0%
TioFrancotirdor
Post by TioFrancotirdor »
Yep. V31 is gorgeus. However on my win 2012 r2 once I play v29,v30 or v31 the songs play but the system hangs. Screen freezes and I cannot move mouse. Keyboard do not work. Should I assign mqn affinity to single core?
Ubuntu Live USB in RAM
