iori
Post by iori »
elaprince wrote:Is there anyway to have that music player folder in different place?
yes and no.
yes (for all w8/ws2012 versions except test ver ) if all necessary files : mqncontrol.exe, mqnloader.exe, mqnplay.exe, paste.exe and mqn.bat are within the same folder, and the mqn.bat is modified with this line "cd c:\musicplayer" disabled by adding a "rem" in front.
the line should look like this : rem cd c:\musicplayer
no (for recent win10 versions) - mqnplay.exe (v36) is still hardcoded to access C:\musicplayer
I used to keep different versions under different sub folders with descriptive names for easy reference and comparison.
BTW, with mqnPlay v36, control/loader v25 and win10 Home (clean install), I thought I was listening to LP12.
elaprince
Post by elaprince »
Thank you
Will try it now
Let you know if it works
elaprince
Post by elaprince »
It doesn't work
I use win 2102r2
I did modify MQn.bat with your line and still gives an error that cant find c:musicplayer loader and play
Any other ide what I could be doing wrong?
Or maybe you can post whole MQN.bat modified ?
Thank you
iori
Post by iori »
this is my mqn_noParam.bat
I had the [for /F "usebackq delims==" %%i IN (`sort Files.txt`) do echo %%~ni ] sections disabled to play files with name in double byte for CJK (Chinese, Japan, Korean), though this should'nt be the cause.
Code: Select all
@echo off
rem =====  this path reference is not a must, as long as all required files are placed under same folder ===
rem =====  multiple folders in different names can be made to describe version and sonic characteristics ===
rem c:
rem cd\MQn\20131020_268sse4intel
Title MQn - Just good music
taskkill /fi "PID gt 0" /IM mqnplay.exe /F >nul
taskkill /fi "PID gt 0" /IM mqncontrol.exe /F >nul
rem net stop "Desktop Window Manager Session Manager"
del Files.txt /q
FOR /F "tokens=*" %%A IN ('CHCP') DO FOR %%B IN (%%~A) DO SET CodePage=%%B
chcp 65001
rem === changes to handle blank Files.txt under Win 7 ==================================================
rem === sorting of track order for files copy and folder copy is lifted ==== applicable to Win 8  ======
paste > File1.txt
rem paste > param.txt
rem echo off
rem file
rem for /F "usebackq delims==" %%i IN (`sort param.txt ^| FIND /I ".wav"`) do echo %%i >> File1.txt
rem if exist file1.txt goto :crlf
rem folder
rem for /F "usebackq delims==" %%i IN (`sort param.txt`) DO for /f "delims=" %%f in ('dir /b "%%i\*.wav"') do echo %%i\%%f >> File1.txt
rem :crlf
rem ====================================================================================================
rem remove cr/lf from last line
setlocal DisableDelayedExpansion
set "firstLineReady="
    for /F "eol=$ delims=" %%a in (File1.txt) DO (
        if defined firstLineReady (echo()
        set "firstLineReady=1"
        <nul set /p "=%%a"
) > Files.txt"
del File1.txt /q
CHCP %CodePage%
cls
set TIMESTAMP=%TIME:~0,2%:%TIME:~3,2%:%TIME:~6,2%
echo Playback commenced - %timestamp%
echo.
rem for /F "usebackq delims==" %%i IN (`sort Files.txt`) do echo %%~ni
echo.
rem lets play music
MQncontrol --file ".\Files.txt"
 rem pause
exit
@echo on
elaprince
Post by elaprince »
I will copy everything to MQN.bat see if it works
Thanks again
elaprince wrote:It does not work still looking for c folder even after editing
Can someone help with this please?
Thank you
Cannot be done. C:\musicplayer is hardcoded into the programs at the moment AFAIK.
elaprince
Post by elaprince »
I did try it and it doesnt work
If you also have that folder in C: it does work no matter where is MQN.bat located it plays but musicplayer has to be in C:
If there is any other way please feel free to post it
Maybe Gordon can chip in
Aleg seems like you are right again
Thank you
iori wrote:this is my mqn_noParam.bat
Code: Select all
@echo off
rem c:
del Files.txt /q
chcp 65001
paste > File1.txt
rem echo off
rem file
rem folder
rem :crlf
        <nul set /p "=%%a"
) > Files.txt"
del File1.txt /q
CHCP %CodePage%
cls
echo.
echo.
rem lets play music
 rem pause
exit
@echo on
adolfo.a.aguiar
Post by adolfo.a.aguiar »
I need some help. The last MQn version I used successfully was ldn v15. No sound since the device id moved to mqnparam.txt.
The mqnplay versions with hardcoded device id work fine.
The contents of the musicplayer folder is:
The MQn_ is a bat modified to use Foobar, tasker and play flac and mp3. The MQn.bat is the current.
The MQn screen appears
and the mqncontrol screen also opens up and closes after a few seconds.
I use mqndevinfo>>mqnparam.txt to retrieve my dac info.
No sound, no exception...
adolfo.a.aguiar wrote:...
If you have more than one USB sound device connected, remove them all except the one you want the USB deviceID of.
I had multiple connected and I got the wrong one each time until I removed the rest.
iori
Post by iori »
May be I'll try to find out later on, in the work house.
One thing for sure, all my version folders are placed in a separate data SSD. C drive does not hold any version folder or musicplayer. It just serve for OS installation, optimization, again and again.
