Agree with Adam 8.77avx2 is excellent. 8.79avx2 no sound for me
darkpink
Post by darkpink »
*bump
You who go for a headless setup, how do you do it? Currently I use RDM+ and my ipad, but I think it's to clunky and cumbersome. Any tips on a more smoother method?
darkpink wrote:*bump
I do the same thing.
Not cluncky just minimal.
I have no need for fancy UI, as I have a well organised music collection.
Clive
Post by Clive »
I would try 8.77 but the download cupboard is empty :-(
the enumeration code is a bit complicated so shall be a while before the next version.
Clive wrote:I would try 8.77 but the download cupboard is empty :-(
try this link
https://www.dropbox.com/s/22samv78h7gl4 ... 0avx2?dl=0
Clive
Post by Clive »
Thanks Tony!
uploaded 8.80 avx2/normal and 8.77.
8.80 should find a suitable device to play, might only work if you just have 1 device that can play 16/44 as it just uses the first one it finds. Might work for those with pci soundcards and other devices that wouldn't work before as they seem to have 2 pins and this tries all pins up to 5.
I do like the sound of this version, there's just something about it.
gave up on the enumeration bolloeux and just loop through everything until it finds a match, it'll do for just now.
8.81 has a bit more foot tapping potential. difference is use of heapalloc/heapfree vs new/free, think there's a difference.
see it's 5kb smaller, just by using a c command instead of c++.
John Dot
Post by John Dot »
sbgk wrote:uploaded 8.80 avx2/normal and 8.77.
Thank you so much for your effort - no sound this time - there must be something else...
Both working for me so most people should be fine with them. See it is getting very close to the 1mb size.
Sound is excellent only tried a few Nick Drake tracks but really crystal clear edge to these ones. Maybe wasapi threshold is broken?
