lekt player
lekt
Re: lekt player
Post by lekt »
updated to windows build 16299.214
sound more free, better again.
Re: lekt player
gonna update windows later today
Re: lekt player
lekt wrote: Tue Feb 06, 2018 3:00 pm updated to windows build 16299.214
Updated to 16299.248
Yeah better!!
lekt
Re: lekt player
Post by lekt »
my OS now 16299.248
downloaded Intel® Graphics Driver from Intel site and updated.
bass much better, sound more "water", all things are correctly.
lekt
Re: lekt player
Post by lekt »
uploaded lekt.exe v3.78 64
try test, i prefer this new version (buffer frame size 64), vocal have good emotion.
(don't forget run lektmod.exe v2.0 before using lekt.exe)
-----edit----: my win10 updated to 16299.334, sound more clean a bit.
Re: lekt player
lekt wrote: Tue Apr 03, 2018 7:40 pm uploaded lekt.exe v3.78 64
"Can not write soundcard device ID to file "lekt.exe"."
let me update windows to 16299.334
Re: lekt player
updated to windows 16299.371.
now letkmod works!
3.78 64 is rock solid. i mean that bass is rock solid! timing never better. not heard any software can play fast notes as good as lekt.
need more test... wait me...
by the way, 3.78 has bug. sometimes it has constant background noise. after playing for a while, the noise is gone. but after maybe i run chrome or something, noise is back. and then if i do nothing it is gone again
Re: lekt player
3.78 not only all things better, it has all good things in one versions! No obvious weakness. Bass pressure is the highlight.
Bass is rich, yet the sound is clear, first person. The treble shines with warm bass.
Piano notes 'melt' into vibration! It has 'water', but never bright.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote: Sat Apr 14, 2018 1:27 am ...3.78 has bug. sometimes it has constant background noise. after playing for a while, the noise is gone. but after maybe i run chrome or something, noise is back. and then if i do nothing it is gone again
yes, the same in my case, background noise... it uses buffer frame size 64 (and the same in case 128). but this code for size 256 works normally.
my onboard sound card can play minimal 160 (by report of wasapi function), but lekt's code now can make its playing for 128, 64. here's bug somtimes raises, i will learn more, what reason.
my win10 now also 16299.371.
Re: lekt player
lekt wrote: Sat Apr 14, 2018 5:55 am yes, the same in my case, background noise... it uses buffer frame size 64 (and the same in case 128). but this code for size 256 works normally.
Lekt can you upload a 256 version?
