lekt player
lekt
Re: lekt player
Post by lekt »
uploaded lekt.exe1644 v1.7 with well improved bass, more detail, more analog. sound good and correct vibrate, i think that.
try it for musical emotion.
Re: lekt player
lekt wrote:uploaded lekt.exe1644 v1.7 with well improved bass, more detail, more analog. sound good and correct vibrate, i think that.
1.8 and 1.81
-much better than 1.7 and earlier versions.
-much prefer 1.8 only because it is extremely airy while having lots of vibration.
-comparatively, 1.81 is either rich or slightly bloated. not sure which.
-i love the tune. treble and bass balance is amazing. the tune is totally sweet. not an ounce of soarness. every player XA, MQn, youtube flash, foobar, sometimes has soared trebles. i thought that's a flaw of win8/2012 because in win7 isn't much of an issue. you have changed my mind!
-sometimes drums lacks enough depth and weight. wasn't easily noticed coz the stage is very focus on the music.
i cannot properly test! many files cannot play! please fix. thx
John Dot
Re: lekt player
Post by John Dot »
On my system works only lekt.exe1644 v1.4
lekt
Re: lekt player
Post by lekt »
John Dot wrote:On my system works only lekt.exe1644 v1.4
last versions i compiled for x64 base, so you need install Visual C++ Redistributable for Visual Studio 2012 Update 3 (2 file vcredist_x64.exe and vcredist_x64.exe). download link:
https://drive.google.com/folderview?id= ... sp=sharing
Best Regards.
John Dot
Re: lekt player
Post by John Dot »
Best Regards.
Thanks but still not working.
Clive101
Re: lekt player
Post by Clive101 »
Hi lekt
Do you have a version that supports 24 bit DACs ? My Dac only works with everything sent in 24 bits - even 16 bit wavs, which is a bit annoying.
Clive
lekt
Re: lekt player
Post by lekt »
if have issue with missing .dll file, need install Visual C++ Redistributable for Visual Studio 2012 Update 3 (2 file vcredist_x64.exe and vcredist_x86.exe)
v1.7, v1.8, v1.8.1 still have'nt fixed error with crash when double-click .bat file. be careful double-click .bat to run player. some time run OK, sometime crashed, try 2, 3 times, slower double-click. so these versions only for testing, maybe not for listening. sorry, i will try fix it.
lekt
Re: lekt player
Post by lekt »
Clive101 wrote:Hi lekt
Clive
play 16bit source in 24bit container in my plan. i will make it and notice to you.
Clive101
Re: lekt player
Post by Clive101 »
Clive
Thank you - it would be great to test :)
Clive
lekt
Re: lekt player
Post by lekt »
fixed error crash when double-click .bat.
uploaded v1.8_v2 , v2.6
(1.xx : read from file; 2.xx : load into RAM and play from it).
try for enjoying.
