JLP wdm-ks player
cvrle59
Re: JULF Player
Post by cvrle59 »
sbgk wrote:just uploaded affinity set for 2 and 4 core. I'll do an unset later. Makes a difference, puts squeezelite-win.exe on core 1, everything else on core 0 or 0,2,3 depending on which version is run.
How do you use it?
Do you stop LMS, and you load that program, or something else?
Re: JULF Player
How do you use it?
just double click on the version you want to run, no need to stop anything. You could have a batch program to start lms, pause 10 seconds and then run the affinity program.
Re: JULF Player
Just uploaded v17 pa dll and squeezelite, this uses the same code, just compiled with a GF- option, think this is the same as MQn and adds the attack back into the sound.
cvrle59
Re: JULF Player
Post by cvrle59 »
sbgk wrote:
How do you use it?
It is complaining that MSVCP120.dll is missing when I try to run it?
Re: JULF Player
cvrle59 wrote:It is complaining that MSVCP120.dll is missing when I try to run it?
ah, ok shall sort that.
Re: JULF Player
v16 GF- not so good, just serves to show how good v16 is, identical code, just a different compiler setting.
Re: JULF Player
you need to download http://www.microsoft.com/en-gb/download ... x?id=40784
cvrle59
Re: JULF Player
Post by cvrle59 »
Fixed...thanks!
Re: JLP wdm-ks player
renamed to JLP - JULF was just too long winded and didn't add anything to the SQ
jumped up little player has a cheeky ring to it.
is the affinity set file to go in to the bin file with the squeezelite.exe and .dll??
