OS in RamDisk
adolfo.a.aguiar
Re: OS in RamDisk
Post by adolfo.a.aguiar »
Managed to make MQn work with the OS in RamDisk, bypassing paste.exe.
I think the best solution will be to code paste.exe in C++. I will use Reflector.
Thank you all for the suggestions.
Adolfo
Octagon
Re: OS in RamDisk
Post by Octagon »
adolfo.a.aguiar wrote:I think the best solution will be to code paste.exe in C++. I will use Reflector.
Hi Adolfo,
You might try Taggarts MQNload, download latest version from here:
https://www.dropbox.com/sh/u71wm4ki02vdvg6/p-DhIcn5L0
There is a description about usage in the folder when you have extracted it. You can also find a description of the tool on page 295 of the MQn thread in this forum from oct, 2013. As far as I understood Christoph it is written in C++.
Take care
Thomas
elaprince
Re: OS in RamDisk
Post by elaprince »
Guys have a question
I finish creating VHD system disk got booted no problem Mqn works no problem
I have 8GB of ram so I compacted to 3.9GB and booted no problem few times to make sure
Now if I want to play MQN needs .net 4.0 something to work
Can you help with this issue please?
Or what I am doing wrong??
Thank you
Re: OS in RamDisk
elaprince wrote:Guys have a question
Thank you
Is that looking for .netframework? If so same thing that happened to my install. I think you will need to go again from the start. Been too lazy well to be honest no time at present to go back and do the complete install again. It doesn't work if mobo set to UEFI. Need to refresh my mind exactly what needs to be changed but the install will boot up fine but will not play MQn you just keep getting the .net error.
See earlier posts on this thread it sort of covers what happened
elaprince
Re: OS in RamDisk
Post by elaprince »
Thank you for suggestion
I didnt set it to that I dont think
I will to try what Aleg suggest to edit compacter file for net 64bit
Re: OS in RamDisk
elaprince wrote:Thank you for suggestion
You need to read the previous page again Elaprince...all your answers are there!!
Adolfo went through the very same Q&A and came up with a solution, its all in the thread as I described in PM.
Cheers, Pearse.
adolfo.a.aguiar
Re: OS in RamDisk
I recoded paste.exe with C++ and I don't need .Net anymore.
Using MQnLoad as suggested by Octagon would be an alternative but I'm using Foobar as GUI and prefer to keep it like that.
Adolfo
Re: OS in RamDisk
adolfo.a.aguiar wrote:I recoded paste.exe with C++ and I don't need .Net anymore.
Adolfo
Hi Adolfo Could you dropbox that recode?
Octagon
Re: OS in RamDisk
Post by Octagon »
adolfo.a.aguiar wrote:Using MQnLoad as suggested by Octagon would be an alternative but I'm using Foobar as GUI and prefer to keep it like that.
Hi Adolfo,
Great you did geh it working! MQnload would work with Foobar as well.
Take care
Thomas
adolfo.a.aguiar
Re: OS in RamDisk
Adolfo
______________________________________________________________________________________________
https://drive.google.com/folderview?id= ... sp=sharing
If you don't have Visual Studio 2013 in the machine, you'll have to install the KBs and redist in the folder "Windows for paste" in the order specified in the text file. It is still much lighter than .NET.
Adolfo
