How do I begin?
Re: How do I begin?
bust a gut laughing on this
interesting amp
what was the other amps you auditioned
have you installed the drivers for the dac?
tipdrinker
Re: How do I begin?
Post by tipdrinker »
yep, i think so. i can see the little green meters going up and down when i select it under audio devices but no sound.
primare i22 - good clarity but treble was a little shrill sometimes
micromega ia60 - in between the primare and arcam in terms of tone but the bass was muddy i felt (my gf agreed)
arcam something. lacked clarity in the top end, overly 'warm' which suited some music and not others, i didnt listen to this as much though. sorry i cant remember the name. it would have sat higher than the amp i have but was perhaps two generations previous.
arcam fmj a29 the 'warmth' was more refined, the low end was more present than all the others and decent treble (the winner for me)
Re: How do I begin?
tipdrinker wrote:I'm still unable to get the dac sending a signal so I've a simple line out from the sound card going at the moment. It's still very good. I'm sure sligolad will be able to help me out in this regard.
Hi TD, was out of town the weekend so just catching up.
To try and get you going have a look here for the Driver based on whichever OS you are running http://www.m2tech.biz/it/youngdsd.html
Then go here for the Young DAC Manual which has good installation guide and helps get Windows setup.http://www.twctokyo.co.jp/m2tech/Young% ... %201-0.pdf
What OS and playback software are you using?
If you have a Kernel Streaming option in your software then select that as it is often the better option.
If you are still struggling I will arrange to call round and hopefully get it going.
Cheers, Pearse.
Re: How do I begin?
Pearse, is this one of the JKDAC32's that uses a Vitus Audio chip?
Tipdrinker, check sound devices on ControlPanel/Device manager and if you see a yellow triangle and Vitus Audio , this could be the problem. First install the Young driver from here http://www.m2tech.biz/it/young.html#style and then back to control panel , select the Vitus Audio device, update driver and choose to update from drivers on the computer , find M2Tech drivers, use the Young driver and when your PC says it's not correct, keep going.
Hope this helps.
Re: How do I begin?
Ken's advice if you have pc should do it but if you are using an apple the young driver has problems with mavericks
tipdrinker
Re: How do I begin?
Got the dac working yeay, not sure what worked but something did lol. Sligolad was over to help me out, sorted me out with jayplay and some of his flac tracks which was very generous of him.hanks a mill! Now I'm sitting back enjoying all my fave tracks all over again. ahhh!
Re: How do I begin?
tony wrote:Ken's advice if you have pc should do it but if you are using an apple the young driver has problems with mavericks
keep with the times tony there's two os releases since mavericks :)
Re: How do I begin?
tipdrinker wrote:Got the dac working yeay, not sure what worked but something did lol. Sligolad was over to help me out, sorted me out with jayplay and some of his flac tracks which was very generous of him.hanks a mill! Now I'm sitting back enjoying all my fave tracks all over again. ahhh!
that's great
the really is fantastic computer audio knowledge and help here
how are you finding Jplay any improvement for U ?
tipdrinker
Re: How do I begin?
that's great
tbh i havent used it much. i didnt notice much of a difference and it seemed to crash a fair bit. using music bee atm.
