Another interesting r2r dac
Re: Another interesting r2r dac
randytsuch wrote:I only see a completed DAC on their page.
They don't sell just the little boards, right?
http://www.audio-gd.com/Pro/diy/DA01/DA01EN.htm
go on....... you know you want too......
randytsuch
Post by randytsuch »
Maybe :)
Still recovering from Christmas spending, so I'll have to wait a bit.
randytsuch wrote:Maybe :)
yea this is far more flexible than soekris we have more control
makings of an interesting project
adolfo.a.aguiar
Post by adolfo.a.aguiar »
Regarding Audio-gd DA-M1, the output is 800mV RMS at 47ohm. Will this drive the Salas DCB1 pre-amp?
In the DA-M1 page, there are suggested analog output stages. Any ideas on suitable op-amps?
Kingwa says Audio-gd will design and sell an output stage for the DA-M1 if it sells well.
adolfo.a.aguiar wrote:Regarding Audio-gd DA-M1, the output is 800mV RMS at 47ohm. Will this drive the Salas DCB1 pre-amp?
soekris is 1.2v and 625 ohm so 800 is just lower volume
dcb1 is just a buffer so will work the same as before
maybe an active transistor preamp
abraxalito
Post by abraxalito »
adolfo.a.aguiar wrote:Any ideas on suitable op-amps?
If you stoop as low as opamps, why not just get a DAC which already contains opamps? I reckon the whole point of R2R type DACs is to get a more tonally pure sound, one which is likely to be corrupted by the introduction of a weakly biassed classAB stage (as all opamps have).
adolfo.a.aguiar
Yes, that's also Kingwa's opinion.
The Audio-gd output stage would be discrete (although they draw an op-amp in the website).
wushuliu
Post by wushuliu »
And yet another r2r dac. Less than 500!
http://www.denafrips.com
Hifime Es9038Pro
3eaudio TPA3251
rickmcinnis
Post by rickmcinnis »
Nigel is right.
This would be more interesting with many of us using this board.
I am not interested in balanced but what thoughts are thgere about the "push-pull" configuration?
At this price why not get four boards?
I am ready for something different. Just sent an inquiry for four boards.
For a buffer ZEN MOD's (DIYAudio - Pass Forum) up and coming diamond buffer is promising.
abraxalito
A diamond buffer suggests push-pull. I'd suggest an SE buffer is more likely to sound transparent than a push-pull.
