I have one of those ( or very like it - essentially using ESP8266 for control) but sonically its well off the original one here. Brilliant as a standard player though, and will play from usb or SD card.
abraxalito
Post by abraxalito »
This one's using an ATS2825 - it doesn't mangle the ends of tracks like the more expensive one so I'm preferring it. So far its been the height of stability, nothing fazes it, not even pulling out the card while playing, it mutes gracefully.
cristianr
Post by cristianr »
Hello, This website does not work any more https://sites.google.com/view/randy-aud ... /sd-player. Does anyone has a copy of the informations in it? Thanks.
randytsuch
Post by randytsuch »
cristianr wrote: Sat Mar 09, 2019 8:30 pm Hello, This website does not work any more https://sites.google.com/view/randy-aud ... /sd-player. Does anyone has a copy of the informations in it? Thanks.
Try it again, I accidentally broke the link
cristianr
Post by cristianr »
It works. Thank you for your effort writing this guide.
jp2018
Post by jp2018 »
I don't really like the remote that came with my sdplayer, my Samsung S6 works much better as remote. I Don't have to aim it towards the ir receiver like I have to do with the original. I tested different remote apps, Irplus works well and it's free. I don't know if anyone finds this useful but here is my configuration for sdplayer, create a new remote in irplus and paste this in:
<irplus>
<device manufacturer="2WIRE" model="2WIRE" columns="30" format="WINLIRC_NEC1" one-pulse="585" one-space="1662" zero-pulse="585" zero-space="538" header-pulse="9024" header-space="4462" bits="16" pre-bits="16">
<button label="&#61457;" labelSize="25.0" span="10" backgroundColor="FFC84334">0x4F9 0x00FF</button>
<button label="BACK" labelSize="18.0" span="10">0x4F9 0x807F</button>
<button label="MENU" labelSize="18.0" span="10">0x4F9 0xC03F</button>
<button label="VOL+" labelSize="18.0" span="10">0x4F9 0xF00F</button>
<button label="&#61656;" labelSize="25.0" span="10">0x4F9 0xA05F</button>
<button label="&#1044556;" labelSize="25.0" span="10">0x4F9 0x50AF</button>
<button label="&#61657;" labelSize="25.0" span="10">0x4F9 0x10EF</button>
<button label="OK" labelSize="25.0" span="10">0x4F9 0x906F</button>
<button label="&#61658;" labelSize="25.0" span="10">0x4F9 0x50AF</button>
<button label="VOL-" labelSize="18.0" span="10">0x4F9 0x30CF</button>
<button label="&#61655;" labelSize="25.0" span="10">0x4F9 0xB04F</button>
<button label="SEARCH" labelSize="18.0" span="10">0x4F9 0x906F</button>
<button label="&#61515;" labelSize="25.0" span="15">0x4F9 0x906F</button>
</device>
</irplus>
seeteeyou
Post by seeteeyou »
About $230 with two I2S outputs, only USB drives are supported and no SD card slots
https://item.taobao.com/item.htm?id=593693634240
seeteeyou
Post by seeteeyou »
Jueling J12P will be superceded by J16D / J16P / J16R
https://item.taobao.com/item.htm?id=601768022012
tapatrick
Post by tapatrick »
Link seems broken again. @randytsuch. Can you please fix?
randytsuch
Sorry, I kind of accidentally renamed my wiki
https://sites.google.com/view/audiostuff/sd-player
