Sold.. willsenton R8 tube integrated amplifier
For Sale/Wanted
It's a bloody impressive amp - seriously well built and part of a whole new era of high quality, high value Chi-Fi products.
It's not just hype that a lot of audiophiles sold their beloved McIntosh (and similar) amps once they heard the R8. Three inputs, a choice of output tubes (KT88 or EL34). change tube output from Triode to Ultra-liniar from the remote while you listen. I found out that Amy Winehouse had a very bony arse because she was sitting on my knee when I listened in Ultra-linier.
The remote is all metal and it can rattle but you could drive a truck over it with out doing damage. A rattle could be cured with some carefully place blu-tac
You can still buy the standard R8 from China landed in Ireland for about €1500 including delivery, taxes and whatever other duties are involved.
My experience was buy/order in May. Daily contact from June onwards as to why my amp hadn't arrived when I knew it was in the country.
and then finally on July 5th I got it home once I found out a Customs Officer made several assumptions (all wrong) I received the amp and an apology almost simultaneously.
I'm looking for a straight €1600 to include upgraded PSVANE preamp tubes and and upgraded voltage regulator tube. I will also throw in four Tesla/JJ EL34 tubes as they work well in this amp. The KT88 tubes are Willsenton's own as they are really very good and the choice of those tubes is easy.
Comes with original double boxed packaging.
Incidentally EL34s are considered more musical, KT88s more 'punchy' - it all depends on your equipment, type of music and mood.
Cyndale
Re: for sale... willsenton R8 tube integrated amplifier
Post by Cyndale »
Are you moving away from valve amplifiers?
Cyndale wrote: Sun Oct 09, 2022 6:43 pm Are you moving away from valve amplifiers?
Never!
I bought this while confined with a broken ankle and it was indeed a lovely amp (the devil will find work for idle limbs to do!) But as we were planning a house move it was easier to put to "go to" amplification into storage and use this in the mean time. My main amp for as long as I can remembers the Airtight ATM1s bought the October 2008! 14 years and it feels as if I've had it forever :) As the Airtight is essentially a power amp with gain via two inputs it became a little restrictive so when serendipity gave an opportunity of a pre amp (fully upgraded) from Wired 4 Sound a few years ago I tried it and it is a great match.
I honestly thought the Willsenton was a match for the the Airtight/W4S combo but after a year or more I recently put the Airtight back in the system and while not a huge obvious difference it was enough to box up the Willsenton. Given that the current combo new would be $9500 + $3500 it's no surprise that it would be "better" than a €1500 amp. What is a surprise is that the difference is subtle. If I didn't have the set up I currently have I'd be very very happy with the R8. It is a massive bargain.
You bought the Air Tights 14 years ago?? Jerciful Maysus...
Diapason wrote: Sun Oct 09, 2022 8:38 pm You bought the Air Tights 14 years ago?? Jerciful Maysus...
I knew it was a while ago but... looked back at the emails with my dealer... Yep. October 2008. Bought the Lector CDP at the same time. All open box
I was on honeymoon in early October 2008. Obviously your Air Tight and Lector purchase is similarly significant in my memory.
Diapason wrote: Sun Oct 09, 2022 9:07 pm I was on honeymoon in early October 2008. Obviously your Air Tight and Lector purchase is similarly significant in my memory.
Would this be a bad time to suggest an integrated tube amp would be the ideal anniversary gift for the wife in your life?
The discreet cartouche is still vacant
She does enjoy the warm glow...
willsandbills
Post by willsandbills »
Hi Ivor. I’m trying to send a pm to you but does not seem to work for me. Can you pm me pls ?. Re willenston
Willie
willsandbills wrote: Sun Nov 06, 2022 6:27 pm Hi Ivor. I’m trying to send a pm to you but does not seem to work for me. Can you pm me pls ?. Re willenston
Willie
PM sent.
Check to see is you have a lot of PMs stored... a good clear out every now and again is needed!
