Glad to see you here.abraxalito wrote:John sent me a link over to this thread, said I had an admirer here so as an incorrigibly attention-seeking guy I couldn't resist signing up.
We will all learn something from your participation.
That's pretty much the same question I'm asking myself about them. Transformers look like an inductor to the driving circuit at lowish frequencies. The value of this inductance is sometimes called the 'shunt inductance' or 'magnetizing inductance' or 'primary inductance'. Given its an inductor the impedance of it depends on frequency. So the question is 'What frequency is the impedance at?'.jkeny wrote: Does this mean that is the impedance that the source will see driving the trafo & the load being driven will also see?
Right, there's no impedance transformation effect when the ratio is unity. So in practice the load will be somewhat heavier than with no transformer in circuit, due to the shunt inductance.Being a 1:1 winding ratio means that it doesn't present a lighter load for the opamp output stage of a DAC to drive?
The small size could be obtained by ferrite too. What suggests steel to me is tradition - I've not so far seen any vendor offering off the shelf ferrite cored transformers for audio use. Even where ferrite is traditionally used (switching power supplies) off the shelf solutions are extremely rare because in power supplies, each application is different. One technical reason ferrite isn't used is lowish inductance compared to steel.BTW, does the small sizes of these trafos (28X23X16mm) (18X14.5X13mm) suggest steel cores rather than ferrite?
Volt-seconds means a product of volts with seconds, multiplying them together. The lowest frequency the transformer needs to handle gives us the 'seconds' part of this product. The voltage that the transformer needs to handle at this lowest frequency gives us the 'volt' part.jkeny wrote: My question is - I know what low frequency I want (20Hz) but how do I know what Volt-seconds I want?
At this point I get lost with your questions as in this context its about electrical signal levels, not sound. So I have no idea how to formulate an answer.How does V-s translate into what we hear?
im not sure if i changed the soekris output from the stated stock "Single ended 1.4V RMS, Zout 640R" when i used 3.3 v for the r2r instead of stock 4vabraxalito wrote:Yes and also the monitor contains a switching power supply so its an 'aggressor' in EMC terms, throwing noise into the system.nige2000 wrote: gnd loop through monitor earth is a common one
Right, didn't you mention the Soekris wasn't buffered so had an output impedance in the region of a kilo-ohm or something? Trafos really do need to be driven by lowish impedances, particularly those examples which were designed for headphones. An optimized line-level trafo would do somewhat better.as the one we tried on the soekris didn't work that great nor sounded good, think we concluded it was the low output of the soekris?
could be a cool solution to funky grounds in hifi
OK, thanksabraxalito wrote:Volt-seconds means a product of volts with seconds, multiplying them together. The lowest frequency the transformer needs to handle gives us the 'seconds' part of this product. The voltage that the transformer needs to handle at this lowest frequency gives us the 'volt' part.jkeny wrote: My question is - I know what low frequency I want (20Hz) but how do I know what Volt-seconds I want?
Seeing as the thread's about input transformers to amps, the voltage an amplifier normally handles (for full output) is around 1VRMS. So if you want the amplifier to produce its full output voltage when 1VRMS is applied to the transformer the 'Volts' part of this equation becomes 1.41 (its the peak voltage we need). If you want to connect this transformer direct to a CD player (say in an application where you're using a digital volume control within the CD player) then you might want a higher voltage capability because usually CD players output 2VRMS maximum. But then again you might stick with 1VRMS and accept that at maximum you'll experience distortion - the transformer will saturate at low frequencies. The distortion the listener encounters will be a strong incentive to 'turn it down'.
A transformer that handles higher voltages needs more turns so as a DIYer it pays not to overspecify this voltage requirement.
i was thinking of it like a refresh ratejkeny wrote:OK, thanksabraxalito wrote:Volt-seconds means a product of volts with seconds, multiplying them together. The lowest frequency the transformer needs to handle gives us the 'seconds' part of this product. The voltage that the transformer needs to handle at this lowest frequency gives us the 'volt' part.jkeny wrote: My question is - I know what low frequency I want (20Hz) but how do I know what Volt-seconds I want?
The reason why the rest of the question makes no sense is because I was interpreting V-s as V/s - in other words volts per second or the risetime of the trafo - it's speed in handling transients
The V-s I would need is 2V at the DAC output but I would be happy that this dropped to 1V on the output of the trafonige2000 wrote: i was thinking of it like a refresh rate
what v-s will you need?
not lookin forward to doin hundreds of turns with wire like thin fragile hair
Is the Soekris internally balanced? If so then a trafo which converted from balanced to unbalanced and adjusted the output level to suit whatever amp you're using would be ideal. I'd expect reducing the Vref to 3.3V from 4V would reduce the output level by under 2dB, not particularly noticeable.nige2000 wrote: im not sure if i changed the soekris output from the stated stock "Single ended 1.4V RMS, Zout 640R" when i used 3.3 v for the r2r instead of stock 4v
Would be right if the Soekris is internally just one DAC element per channel.i suppose i should be looking at a 1.5v rms capable transformer for this app?
Most of the modern ones are like that, from ES9023 and onward. Other older ones have balanced outs they'd be better off having a transformer which uses the balanced capability which might be more than 2V in total.is most dac chips circa 2vrms? meaning they will require at least that capability?
Good idea, I'll see if I can work up a worked example. Tell me what the narrowest wire you're comfortable using is and I can choose a big enough core to accommodate that.maybe if you did a an example solutions based on 2v rms
