Ken Moreland wrote:Yes, the sound of the Core Server stick is a major leap even from the WTG stick with Cad's script. The bass is meatier but not bloated, vocals are more distinct and the top notes are sweet. A real improvement and I was surprised that it worked first time without any ipconfigging etc. Thanks Tony :).
definitely the new standard in os and script
amazed you didn't have to change any of the ip settings
nice to get a bit of luck now and again
Pearse you are having problems with your latest instal on a usb is it a kingston or sandisk?
http://agnipulse.com/2012/11/windows-to ... ndows-7-8/
jk posted this link a while back and it can be used for both kingston wtg drives and the sandisk which requires a virtual hard drive to be installed
Great to see progress on the Core Server stuff
Hope to be able to try this next week or so
I probably should get myself another Sandisk USB stick or is dual boot an option on a USB stick with both Win 8 & Core Server?
jkeny wrote:Great to see progress on the Core Server stuff
Probably best to have two usb3 sticks as dual boots can be a pain in the ass
No reason why you couldn't dual boot though
I just couldn't. Be bothered dual booting especially with all the messing about
Thanks Nige
Yes, you're probably right - I'll get another Sandisk so
tony wrote:Pearse you are having problems with your latest instal on a usb is it a kingston or sandisk?
Hi Tony, no problems with creating the wintogo core server on usb sticks but when I load them on my laptop I can boot up core server OK and set everything up but JPLay Settings window will not open up.
I think it is some issue with a driver or something, seeing as server is built for PCs it may not have everything needed for some laptops.
I tried booting into core server GUI on another disk but it starts looking for some driver which it can not find for my laptop!!
Has anyone been running core server on a laptop yet?
I heard a quick blast of Nigels core server build this evening.... Well suffice to say I'll be going down this route.... Really stunning sounds.
Fran,I had the pleasure of hearing it in the afternoon with your speakers too!The Core Server is superb and Nige's separate power supplies for CPU and USB bring the sound up another notch. The speakers are very nice too and very professional looking with good finish and named and labelled.
Fran wrote:I heard a quick blast of Nigels core server build this evening.... Well suffice to say I'll be going down this route.... Really stunning sounds.
Ah Fran you got to hear it. Sound is magical isn't it.Hard to believe the improvements. The whole package really delivers.
We slowly but surely moved the set up back as far as the spec of my zuma and even when equal the asus build seems to give a little more. I reckoned you would be on to the separate power supplies straightaway. A big lift for small outlay.
