LowOrbit
Post by LowOrbit »
Hi Nigel
Yes in for a penny. Not going to pretend it'll be one step though.
Would this be a workable starting point - http://www.ebay.co.uk/itm/Mini-ITX-PICO ... 27d4e7997b
Mark
LowOrbit wrote:Hi Nigel
Mark
havent come across that one yet good price too
pity the postage to Ireland is so much
can be got cheap from hong kong and china to
but delivery times are terrible
LowOrbit
Post by LowOrbit »
Yes, price is good, UK mainland postage not excessive. May snap one up.
Is the Maplin linear psu adjustable on output voltage. My recollection is they knock out 13.8v by default...
Regards
Mark
Yes thats a under the hood adjustment
probably best shown on the jplay forum
linear supply to pico thread
or you can try the search tab here as
Its in here somewhere too
LowOrbit
Post by LowOrbit »
nige2000 wrote:Yes thats a under the hood adjustment
Cool - will dig it out.
Mark
Mark if you get the maplin it is easy even without pictures to identify the two flathead screws that are turned.
Connect multimeter to positive and ground (Red and Black connectors) Turning the flathead screws one will adjust the Volts. Trial and error will get you there just be careful when you take the cover off.
LowOrbit
Post by LowOrbit »
Chaps
Many thanks. I read the first couple of pages of the thread on the JPLay forum. Great info from you all there. My local Maplin has a couple of in stock so may get a chance to pick one or two up tomorrow.
Mark
Claus
Post by Claus »
Struggling to get the network working with R2. Should I have left out the commands regarding network in the Core install procedure?
If so can I undo these commands?
Thanks. Music and everything else working no prob!
Claus wrote:Struggling to get the network working with R2. Should I have left out the commands regarding network in the Core install procedure?
might have to build the inf file from scratch for the new os
what u need ethernet for?
Claus
Post by Claus »
Files off my NAS. Sorry if I am confusing terms. All is working in device manager but I got a message that the device did not exist on the machine when trying to install the driver from Intel... I tried manual install but got a warning that the driver might not be compatible with device... Might just try and delete drivers and do a fresh install of ME9 (which seems to be needed as well)...
