Claus
Post by Claus »
Thanks for all your help guys. I intend running it as a single PC with jplay and possibly JRiver for more user-friendliness. I am so far looking at this mSata Plextor M5M PX-64M5M which is cheaper (in Denmark and Germany) and faster than Intel 525 series. I am looking at Corsair or Kingston memory:
Kingston SO-DIMM 8GB KIT PC3-12800 DDR3-1600 HyperX PnP 2x4GB
Corsair SO-DIMM 8GB KIT PC3-12800 DDR3-1600 CL9 1,5V Vengeance
Both around the 60 euro mark...
I am right in thinking two 4GB modules is better than one 8GB?
I will wait it out a bit and see how John gets along...
Claus wrote:Thanks for all your help guys. I intend running it as a single PC with jplay and possibly JRiver for more user-friendliness. I am so far looking at this mSata Plextor M5M PX-64M5M which is cheaper (in Denmark and Germany) and faster than Intel 525 series. I am looking at Corsair or Kingston memory:
dont know if two 4gb will be better than an 8g but 2 4's will draw more power and a 8 will let u upgrade to 16gb if required but id doubt its necessary.
corsair and kingston are my favourite two brands, never had to return a kingston ram as of yet
Claus,
The memory I transferred from netbook to NUC is 2 X 4GB S.Skills DDR3 10666 CL9
Don't know if it's optimal or not - I might replace with one 8GB card as it does get warm & the memory boards are stacked one on top of the other
Tumbleweed. ..........
John any progress
Ive started on the build in the streacom case, fitting the passive cpu cooler took a while to fit fiddly thing. Doesnt go above 52 degrees during normal use . Preliminary results look good
We're all waiting!!
My processor is somewhere between germnay and here!
How the hell did you get your pagefaults so low?
Sorry, had to direct my energies to other matters.
Fran wrote:We're all waiting!!
i don't know page faults are not causing me as much hastle as before, ive a few things disabled antivirus, windows defender, search indexing, disabled nvidia driver, disabled all power saving in bios s1.2 esit etc. nothing mad
running a web browser and jriver looses me 1-2 ultrasizes
what heatsink do you have for the i7
jkeny wrote:Sorry, had to direct my energies to other matters.
damn paying job strikes again eh!!
Had an enjoyable listen today to Nige's i3 on my gear and he's getting under 30 in UltraSize (1PC) and the sound quality is superb and I think better than streaming at US=160 (2PC). I tried US on 1PC myself afterwards but I cannot get below about 150 reliably so clearly Nige's PC is really working well. When using Nige's PC as AudioPC with my streaming set-up we couldn't get much better than maybe US=160 so it looks like I have more than one limitation and I suspect the streamer and the network as well. I guess if one is building a dedeicated AudioPC is would be well to consider the streamer and network as well. Jplay do recommend Ethernet connections preferabl crossover with no router.
