Grounding from China!
Re: Grounding from China!
when changing different ground cables between my PC box and Entreq box, I noticed that sometimes my TCXO clock goes crazy and I have to restart my PC!
That's not happening because of the different cables, but just when disconnect/connect the ground cable.
sima66 wrote:when changing different ground cables between my PC box and Entreq box, I noticed that sometimes my TCXO clock goes crazy and I have to restart my PC!
That is the same here when sometimes switching cable or turning devices on. As discussed before it has to be down to sensitivity with grounds or interference from slight fluctuations in power. Don't think anybody has manage to solve that. Maybe Pearse is ok as he is not using batteries. If so then battery implementation could be the prob.
