Mmmmm. Ultrastream will run fine on the local PC, but not across the network, so its something to do with that.
Mind you, I'm running through a router, so I have yet to try a direct connection. There are advantages to that (audioPC not on the network, no need for firewall or defender etc), but its a little messier in use. However, it is the same router and cables that were used on my old P4 audioPC and it would ultra no problem. So it seems to me it must be something to do with the ethernet on the new franzuma.
All to be figured out yet. I can say that I can do hires files in xtream where I was running out of steam earlier.
Happy with the sound, but haven't done any comparisons yet, lots of tweaking to do yet, incl W8 optimisation, remove surplus SW and so on. It'll all take a few nights.
Happy enough for the first run out though.
Pearse - I know connecting up a monitor etc would be a pain, but if you have it out at some stage anyway, would you mind going into the device manager for your zuma and having a look at the ethernet adapter, check what driver and so on you are using?
Hi Fran,
Good news on the build.
In Device Manager I have Network Adaptor:
Intel (R) 82579V Gigabit Network Adaptor
Driver Date 2/29/2012
Version 12.0.150.0
There is an Microsoft Kernel Debug Adaptor also listed !!
Cheers,
Pearse.
The microsoft one is always there probably part of windows operating system.
Fran wrote:Mmmmm. Ultrastream will run fine on the local PC, but not across the network, so its something to do with that.
cant be a hardware problem either driver or software most likely
i assume u tried raising the ultrasize just to get going
then try latency mon to check
curious issue im sure it will be figured out
OK,
I have the same listings as you Pearse but the driver is different - mine is 18.1. I can't find a version just now back as far as 12.1, but I did find the one immediately prvious to 18.1 and will try that.
Feckers.
EDIT: Pearse - they are the standard windows drivers - have them sorted there now.
Fran wrote:OK,
Feckers.
you just removed the driver and then it worked right?
Removed the intel supplied driver, then scanned for hardware changes and windows loaded up the same driver as Pearses.
Have since tried direct ethernet connection (ie crossover) and while it works beautifully with xtream it won't run ultra!
So same issue as Tony nearly it would seem.
Symptoms are:
Pick ultrastream (have tried drivebuffer 0, 1 and 8; US from 250 to 4000). Set to play, screen goes off on the franzuma (ie it is getting that instruction OK) but then only silence. I then have to restart the service on the audioPC. Without the restart service jplaysettings can't find the audioPC. This is indicative of jplay service running.
xtream sounds great though...
Fran wrote:Removed the intel supplied driver, then scanned for hardware changes and windows loaded up the same driver as Pearses.
Symptoms are:
FRUSTRATING
its working in single mode ultrastream?
working with xtream 2pc?
turn hibernate off
power options?
Ok, this is getting "fuzzy"
- Guess each hardware differences between yours & Pearse's has to be identified & tested?
- same network driver
- different DAC Ciúnas - but this has worked at US=30 on Ken's system
It will be interesting to get to the bottom of this
Have you tried wired thru a modem/router on both audio and streamer? Very much hope you dont have the same issue as me.
