ULTRASONIC RECORD CLEANER ?
sdiesel77
Post by sdiesel77 »
Hi Guys,
I have few records that are cracking and was wondering if any of you had an ULTRASONIC RECORD CLEANER and if this was really a good solution?
I saw this one:
https://www.ebay.ie/itm/VINYL-ULTRASONI ... Sw95lXE6kW
Re: ULTRASONIC RECORD CLEANER ?
sdiesel77 wrote: Fri Nov 24, 2017 3:38 pm Hi Guys,
I saw this one:
Fran has one and reckons its good. I might know a guy selling one. I'll check back with him.
I'll pm you contact details tomorrow, it's still for sale.
sdiesel77
Re: RE: Re: ULTRASONIC RECORD CLEANER ?
Post by sdiesel77 »
Ivor wrote:I'll pm you contact details tomorrow, it's still for sale.
Great thanks
sdiesel77
Post by sdiesel77 »
Thanks a lot Ivor. Deal done, machine already at work [emoji14] !Image
Good stuff! It was just serendipity.
Cyndale
Post by Cyndale »
So, how does one dry records with this contraption?
sdiesel77
Post by sdiesel77 »
On a rack or with micro fiber clotheImage
Cyndale
Post by Cyndale »
Ah, that makes sense! I have a Nitty Gritty Record Cleaning Machine about 25 years old now. Was thinking of getting a Project VCS MK2.
How have you found it for cleaning records?
Somewhat related, but this guy has excellent deals on both ultrasonic cleaning fluid and isopropanol:
https://www.adverts.ie/member/654062
He's also a vinyl fan and understands our ways :) so you won't feel like a complete gobshite when you tell him what you want it for!
Cyndale - I don't know that its any better than the nitty gritty or any of the wet vac machines but for me there are a couple of advantages. Most of what I buy is 2nd hand and some is quite dirty. So having a system that I can "soak" the vinyl in first to remove the crud is very handy indeed. Second is that you can run 7 records at a time in this, which greatly speeds up the operation. Lastly, my one at least is far quieter than the wet vac types. There are disadvantages too of course.
