How does a digital volume control work?
Post by james »
I have been thinking about digital volume controls. Suppose you have a 16 bit signal. You could truncate it to 15 bits or 14 bits. But that would only give you 16 volume steps until you had silence. So I presume a digital volume works by subtracting a number anywhere from 1 to 2^16) from the basic sample (I am ignoring problems of negative values, you would have to apply to treat them differently by adding instead of subtracting) before the conversion from digital to analogue.
Is this how things work?
James
abraxalito
Re: How does a digital volume control work?
Post by abraxalito »
Volume controls work by multiplication (by a fractional number, i.e. less than 1) not subtraction. Your initial idea of truncation is a volume control in steps of 6dB - its rather coarse for a volume control but it would work, although rounding together with dither is used rather than truncation to get around a problem called 'quantization distortion'.
Oh I forgot to mention - 6dB reduction is the same as multiplication by 0.5 which is what you get when you shift right a binary number by one place.
Post by james »
