Hello,
I have for sale
https://www.adverts.ie/home-audio/lecto ... c/17976571
Lector Digidrive Tl mk 3 CD transport and to match Lector Digicode 2.24 DAC
Those units have separate, external power supply, so it’s 4 box set.
Lector Digidrive mk2 when I bought was sent and upgraded last year in Lector factory to mk3 version which is their current model. CDP mechanism / laser, new display, servo is changed, microprocessor was replaced.
The Digicode DAC was also modified by Lector with new input card for real 24bit 192Khz on all inputs XLR/ BNC/ coaxial. It does not have USB. It is fully balanced DAC with XLR and RCA outputs. It uses 4 valves.
All the work was carried out in Italy by Lector and I have all the documents proving this.
Further. The DAC was upgraded by Fidelity Audio in UK with better components such as Mundorf and Audio Note capacitors. I have full list of the components and this is also documented
https://www.fidelityaudio.co.uk/lector-324-c.asp
There are new XLR tellurium copper inputs and outputs fitted; RCS sockets were replaced too.
All the plexi on both Digidrive and Digicode were polished so they look pretty good, almost like brand new.
Boxes / booklets / remote control are included.
I am looking for €3000 for both CD transport and the DAC.
If you are interested I have also 2 cables AES/ EBU from XLO Unlimited series and Audio Quest Eagle Eye BNC to Coaxial cable to connect 2 units.
Domo is welcome.
Regards
Maciej
SOLD Lector Digidrive Tl mk 3 CD transport and Lector Digicode 2.24 DAC
Re: Lector Digidrive Tl mk 3 CD transport and Lector Digicode 2.24 DAC
Somebody is going to get a serious bargain.
Ah, that is one lovely CD player. Best of luck with the sale Maciej.....
Thanks Ivor, Fran.
I try to add some photos within next few days
Maciej
Maciej
PM sent.
